  • 2 weeks later...
You're going to have to roll your own on this one using the Protocol block.  Here's the protocol description-
http://www.sick.com/pl/pl-pl/home/products/product_portfolio/safe_control_solutions/Documents/FlexiSoft_RK512_Protocoll.pdf
If you're not familiar with the protocol block start by looking at some of the Protocol FB examples under the Communications directory in Help->Examples.  Hopefully you only need a couple of the functions.  You'll have to write code to calculate the pieces that the protocol frame needs and use the Protocol block to stack them together.  This one will be a challenge.
Good luck.
