xquter Posted April 15, 2014 Report Share Posted April 15, 2014 Hello, I am using two Vision V130-J to establish a RS485 connection, so that I can remotely access them through Vision Software Remote Access. My communication connection is from PC i connect to M90-19-R4 and from M90-19-R4 to one Vision V130 and from it to other Vision V130 (see Attachment 2) . I have changed the jumper setting of both Vision V130 Controller, similarly I also adjusted the switched setting of M90-19-R4. But unfortunately when i am trying to communicate on the network it showed (See Attachment 1). Can anyone here please give me some guideline any programming example, communication arrangement anything so that I can find a way. Please Help me Out. Regards. Attachment 2.pdf Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted April 16, 2014 MVP 2021 Report Share Posted April 16, 2014 Try only connecting one V130 at a time and set the unit ID to 1. The Help is kind of dated for RS485 on the V130. How do you have the jumpers set on the -R4? Joe T. Quote Link to comment Share on other sites More sharing options...
xquter Posted April 18, 2014 Author Report Share Posted April 18, 2014 Dear Joe, Thanks a lot for you quick response, the Jumpers JP1, and JP2 are on position B, and JP3 and JP4 are on position A. Whereas the DIP switches setting of R4 are on the default setting i-e 10bit, 1 start bit, 7 even bits, a parity and a stop bit, half duplex and a baud rate of 9600.(See attachment 1). I was thinking about the M90-19-R4, wiring arrangement I made it as per the manual (See attachment 2). Can you please guide me about the wiring also. Awaiting for you response. Regards. Quote Link to comment Share on other sites More sharing options...
xquter Posted April 18, 2014 Author Report Share Posted April 18, 2014 Kindly Reply Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted April 21, 2014 MVP 2021 Report Share Posted April 21, 2014 Try the 11 bit setting. Joe T. Quote Link to comment Share on other sites More sharing options...
xquter Posted April 21, 2014 Author Report Share Posted April 21, 2014 OK Joe I"ll and let you know, whats your opinion regarding the wiring of R4 ? Regard. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted April 21, 2014 MVP 2021 Report Share Posted April 21, 2014 It looks right from what you posted, but you didn't show how you connected it to the V130. If you still have problems with 11 bits then try swapping the polarity of the RS485 signal on the V130. It won't work if they're backward. Joe T. Quote Link to comment Share on other sites More sharing options...
