Adcontrols Posted January 7 Report Share Posted January 7 On 10/5/2023 at 7:10 AM, David_2019 said: I suggest adding an in HMI attribute for each Layers Tag: Visibility This will make it easier to draw different screens by selecting only the "Layer Tag Visibility" parameter. If the parameter is not entered, Layer is active, and the "Tag Visibility" parameter of each element takes effect - this will maintain compatibility with all previously written applications. Agreed, I use a screen struct to manually do this. It would be great if UniLogic auto generated the struct instance for every screen... similar to when you make a new datatable or trend Quote Link to comment Share on other sites More sharing options...
kvlada Posted April 25 Report Share Posted April 25 It would be great to have a logic function which gives you a number of ones or zeroes in a register or array of bits. It's super useful when you want to check for condition if only one bit is on at a time. Good for checking some input conditions. For example: 0001011 (0x17) would output 3 (as there are 3 ones). Bit array "0000000000000001000000" would output just 1 because there's just one logical true bit. Sure, it could be done via software, but a dedicated function for that would be a time saver. Quote Link to comment Share on other sites More sharing options...
curtharrington1 Posted April 25 Report Share Posted April 25 1 hour ago, kvlada said: It would be great to have a logic function which gives you a number of ones or zeroes in a register or array of bits. It's super useful when you want to check for condition if only one bit is on at a time. Good for checking some input conditions. For example: 0001011 (0x17) would output 3 (as there are 3 ones). Bit array "0000000000000001000000" would output just 1 because there's just one logical true bit. Sure, it could be done via software, but a dedicated function for that would be a time saver. you could make your own block and then call it whenever you need: FUN_isArryBit.ulle 1 Quote Link to comment Share on other sites More sharing options...
