vanecuci Posted July 22, 2014 Report Share Posted July 22, 2014 Hello I want to know is there a way to determine how much of my operand memory I'm using? Quote Link to comment Share on other sites More sharing options...
EduMarg Posted July 24, 2014 Report Share Posted July 24, 2014 Hello, Currently this option is not available in UniLogic. regards Quote Link to comment Share on other sites More sharing options...
AlexUT Posted July 21, 2020 Report Share Posted July 21, 2020 Hi, You can find answers in following post: As well, visit Unitronics Helpdesk Portal http://support.unitronics.com/ and search for "memory". You will find some information. B.R. Quote Link to comment Share on other sites More sharing options...
Annatooli Posted July 22, 2020 Report Share Posted July 22, 2020 You can look how much memory your projects consumes. If you look "Output" tab after compilation. Look there "Allocation Info", it should give you some idea how much memory is left. 1 Quote Link to comment Share on other sites More sharing options...
