CFBFP Posted August 9, 2014 Report Share Posted August 9, 2014 Hi I tested a new SM35 and the analog inputs are both not responding as I expect: Having connected a 0-10V signal at born 10=I5-AN1, the value i get fluctuates only between 934 and 973. Disconnecting input gives me also the 934 value. I expected to have 0-1023 or so. Jumper settings are: JP4 and JP8 set on "B" JP10 and JP9 set on "A" JP12 set on "A" in Attachment my simple program to check this analog input. Can'f figure out what I'm doing wrong. Can I somehow reset the firmware to default? Please help f. AnalogIn Test.vlp Quote Link to comment Share on other sites More sharing options...
sgull Posted August 10, 2014 Report Share Posted August 10, 2014 Hi I think you need to use the "linearize" function to get the raw 0-1023 value to display the values you want to see. Try attached file. Regards Denis Quote Link to comment Share on other sites More sharing options...
CFBFP Posted August 10, 2014 Author Report Share Posted August 10, 2014 Hi I tried the program, still getting no exact values: the MI4 goes from 91 until 95 (according to 934 and 973 for MI2). Your program is certainly ok and was a help for me. I think my SM35 is simply broken! I will return the instrument to factory. tx for your help! f. Quote Link to comment Share on other sites More sharing options...
sgull Posted August 11, 2014 Report Share Posted August 11, 2014 Hi According to your first post you have set JP12 to "A" which in NPN(sink) digital inputs. According to the Samba specification NOTE 2 "• If the digital inputs function as npn, analog option is not available." Try setting JP12 to "B" and see if this works. Also change your wiring for PNP digital in. Regards Denis Quote Link to comment Share on other sites More sharing options...
CFBFP Posted August 11, 2014 Author Report Share Posted August 11, 2014 Hi setting JP12 on B was the reason as you suggested! It finally works!!! Fantastic, I'm grateful. Problem solved. f. Quote Link to comment Share on other sites More sharing options...
