sandreou Posted December 14, 2010 Report Share Posted December 14, 2010 Hi I have new Dell Desktop PC with windows 7 professional 64bit and visiLogic 8.6.3. I am able to use the onboard serial port to download my programs to the Vision280 BUT when i try to update the OS of the Vision280 the communication fails. I try the same think on my laptop with usb to serial adaptor that i recently installed windows 7 professional with visiLogic 8.6.1 and i have the same problem. Please advise Quote Link to comment Share on other sites More sharing options...
sandreou Posted December 15, 2010 Author Report Share Posted December 15, 2010 I hope I can get an answer as soon as possible I ve been using VisiLogic since 2006 with Windows XP. I was able to update the OS firmware of all of my Vision280 PLCs without any problems. I was using either the onboard serial com of my desktop PC or the usb to serial adaptor of my laptop. Since my upgrade to windows 7 I am not able to perform an update of the OS firmware. I can only download the source code on the Vision280 PLC. I was wondering if it has something to do with the default com port settings of Windows 7. Quote Link to comment Share on other sites More sharing options...
Damian Posted December 16, 2010 Report Share Posted December 16, 2010 I hope I can get an answer as soon as possible I ve been using VisiLogic since 2006 with Windows XP. I was able to update the OS firmware of all of my Vision280 PLCs without any problems. I was using either the onboard serial com of my desktop PC or the usb to serial adaptor of my laptop. Since my upgrade to windows 7 I am not able to perform an update of the OS firmware. I can only download the source code on the Vision280 PLC. I was wondering if it has something to do with the default com port settings of Windows 7. Try running in XP Mode. Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted December 19, 2010 Report Share Posted December 19, 2010 VisiLogic & UAC Windows7 Reinstall Instructions.pdf Please try to perform a proper reinstall of VisiLogic 8.6.3 by following the attached instruction set for a Windows7 machine which also requires the turning off of UAC and certain folder directories to be deleted as specified. Thanks, Quote Link to comment Share on other sites More sharing options...
