DaveE Posted August 19, 2014 Report Share Posted August 19, 2014 Good Afternoon I think I am missing something but, I am pretty certain I looked everywhere, including the examples, but cannot find what I need! I am trying to connect 4 printers to the PLC through ethernet I want to make the IP address of the printers variable, so I can set the printers up when I get them I am confused as to how to set up the system to do that I thought I had it when I set up 4 clients, but then couldnt work out how to change the IP address Anyone got a clue for me? Thanks Guys (and Gals) Quote Link to comment Share on other sites More sharing options...
EduMarg Posted August 20, 2014 Report Share Posted August 20, 2014 Hello DaveE. In the UniLogic examples, under communication/protocol you will find an example called UniStream_070_TCP_Client_Server_Send_Message This examples can work as basis for your application. For printers is more or less the same ID. but in message composer you need to compose the message acording to the printer protocol. In the example you will see you can choose the IP address of the device you will like to send the message. Please let us know if this works for you. If you need more help fell free to contact support at support@unitronics.com UniStream_070_TCP_Client_Server_Send_Message.ulpr 1 Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted December 31, 2014 Report Share Posted December 31, 2014 Good Afternoon I think I am missing something but, I am pretty certain I looked everywhere, including the examples, but cannot find what I need! I am trying to connect 4 printers to the PLC through ethernet I want to make the IP address of the printers variable, so I can set the printers up when I get them I am confused as to how to set up the system to do that I thought I had it when I set up 4 clients, but then couldnt work out how to change the IP address Anyone got a clue for me? Thanks Guys (and Gals) Hi DaveE Please see the attached project. It uses the PCL5 protocol to print text to any TCP printer communicating with this protocol. Also attached is a quick reference guide for the protocol. PCL 5 Quick Reference Guide.pdf UniStream_070_TCP_Printer_30_12.ulpr Quote Link to comment Share on other sites More sharing options...
