Dave Posted August 20, 2014 Report Share Posted August 20, 2014 Hello All. I was just wondering if there are system registers that contains the value of the PLC NAME ( set with the Set PLC Name function block )? I had a look through, but didn't find any. Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted August 20, 2014 Report Share Posted August 20, 2014 Hi Dave, There aren't any accessible registers that contain the PLC Name. However, if you need a way to recognize a PLC, you can use SDW9, which contains a unique PLC ID number. Quote Link to comment Share on other sites More sharing options...
