building a string using multiple MI values
Hi,
I'm using V1210 and i want to build a list of strings from MI values coming from a table:
For example:
line1
MI100=4
MI101=30
I want a string DW1 with '4 min 30'
lin 2
MI102=5
MI103=40
DW2 must be '5 min 40'
Reason: I want buttons with the complete variable text '4 min 30' on the screen. (to select the correct time)
Is this possible?
Hi,
Thanks for the answer.
Not that easy to build 10 lines but it works :)    Strange there isn't an easier solution for this.  A button behind textfields on the HMI would also work but is not possible...
On the screen I have the different lines displayed now, but how can I highlight the selected option?
See attachment for the example.  I want the selected line in another background color....
is this possible?
Thanks a lot.
