petercolquhoun Posted September 22, 2014 Report Share Posted September 22, 2014 Hi, I am writing an application for the Vision 1210, I have various images and text displays and I have chosen the background colour of my images to be identical to one of the background colours provided by visilogic. In the attached screen shot the list of texts highlighted and the timer variable to it's right have the same background colour (according to the background selection dialogue) but the backgrounds of each variable are subtly different. This is rather irritating because I can't achieve the look I want ie all controls appear to be transparent. I can't see a transparent flag on these controls so I assumed making the background colours the same would have the same effect. Can you suggest anything to fix this?? Pete. Quote Link to comment Share on other sites More sharing options...
HigHTech Posted September 22, 2014 Report Share Posted September 22, 2014 Hi, I am writing an application for the Vision 1210, I have various images and text displays and I have chosen the background colour of my images to be identical to one of the background colours provided by visilogic. In the attached screen shot the list of texts highlighted and the timer variable to it's right have the same background colour (according to the background selection dialogue) but the backgrounds of each variable are subtly different. This is rather irritating because I can't achieve the look I want ie all controls appear to be transparent. I can't see a transparent flag on these controls so I assumed making the background colours the same would have the same effect. Can you suggest anything to fix this?? Pete. Hi Pete For text variables, numerica variables and timer variables you can select the following configuration: Style: FLAT Back Color: you need to select the "blue crystal" at the left side of the OK button. Is like selecting transparent as back color. With image variables things are a little bit complex. If you want great results, then you must manually paint the background of all your images, that´s because when you select the box of transparent background you can lose some zones of your image that you want to keep the same color you are making transparent. That´s why I love Unistream and Unilogic. No matter they upgrade Visilogic to accept PNG format, the transparency didn´t work as you expected. I will try to upload an image. Quote Link to comment Share on other sites More sharing options...
HigHTech Posted September 22, 2014 Report Share Posted September 22, 2014 Hi Pete For text variables, numerica variables and timer variables you can select the following configuration: Style: FLAT Back Color: you need to select the "blue crystal" at the left side of the OK button. Is like selecting transparent as back color. With image variables things are a little bit complex. If you want great results, then you must manually paint the background of all your images, that´s because when you select the box of transparent background you can lose some zones of your image that you want to keep the same color you are making transparent. That´s why I love Unistream and Unilogic. No matter they upgrade Visilogic to accept PNG format, the transparency didn´t work as you expected. I will try to upload an image. Quote Link to comment Share on other sites More sharing options...
petercolquhoun Posted September 24, 2014 Author Report Share Posted September 24, 2014 That's great, thanks for your help. Pete 1 Quote Link to comment Share on other sites More sharing options...
HigHTech Posted September 24, 2014 Report Share Posted September 24, 2014 That's great, thanks for your help. Pete You´re welcome. Quote Link to comment Share on other sites More sharing options...
