petercolquhoun Posted October 2, 2014 Report Share Posted October 2, 2014 HI, I am working with a V1210 and have 3 very similar displays with a number of images in identical locations on top of the background image. I would really like one display in which I could change the background image dependant on the system configuration. I can't see a way of changing the background image from the ladder code, is this possible?? I have tried using a "List of Images" as a background but I cannot place other variables on top of this so this won't work as a solution. Any ideas?? Thank you. Pete Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted October 2, 2014 Report Share Posted October 2, 2014 Hi Peter, It is not possible to change a background image during the PLC runtime. However, you can add another screen with the exact same elements but a different background image, and create a logic to jump to this page when necessary. Quote Link to comment Share on other sites More sharing options...
