RANNUG Posted October 3, 2014 Report Share Posted October 3, 2014 I have a project with V570 and a modem kit 41J attached. I am using this configuration to send sms messages to technical staff when an alarm occurs. The customer also want to be called up, not just a text message. The call up function is most important during night, when sleeping. I have tried tu use the function DIAL but this dont work. Do anyone have a solution to this ?? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted October 5, 2014 MVP 2021 Report Share Posted October 5, 2014 Have you read the Help and looked at the Examples on sending SMS messages? Has the modem been prepared using the Visilogic utility? Post your code so we can have a look at it. Joe T. Quote Link to comment Share on other sites More sharing options...
RANNUG Posted October 5, 2014 Author Report Share Posted October 5, 2014 Have you read the Help and looked at the Examples on sending SMS messages? Has the modem been prepared using the Visilogic utility? Post your code so we can have a look at it. Joe T. SMS works perfect. Customer also want to be called up. Wake up call when sleeping but still at duty. I hav tried DIAL command , but does not work. Alarm 1. send sms to persons on list ( ok) 2. Call up An alternative is to use a digital output to activate standalone caller. Gunnar Quote Link to comment Share on other sites More sharing options...
