Martin1 Posted October 22, 2014 Report Share Posted October 22, 2014 Hello, I'm looking to exchange data from a remotely located Vision130 to a either UniStream or v570 controller using GPRS. 2 Analogs & two digital signals. Is this possible? Would there be any examples of such a setup? Regards Quote Link to comment Share on other sites More sharing options...
s.pratt Posted October 23, 2014 Report Share Posted October 23, 2014 Hello, Thank you for using our Untronics Forum. You should be able to send an SMS text from the V130 to the modem of the other controller at the other side. You would have to interpret the ASCII message on the receiving controller as to what the info is referring to, then use the ASCII to NUM function block to utilize the analog value in the receiving controller. For simple digital values, though, the SMS scan function block will flip an according bit on when the message matches to a correlating message in the configuration. To receive an ASCII message into a vector of MIs, turn SB199 on, then put the address number of the MI address you wish the vector to go into in SI199. This is all outlined in the help files as well. Hope this helps. Quote Link to comment Share on other sites More sharing options...
s.pratt Posted October 23, 2014 Report Share Posted October 23, 2014 Also, you can communicate Modbus via GPRS. We have an example of a Modbus Server and Client; please e-mail into support@unitronics.com for an example of how to achieve this set-up. Quote Link to comment Share on other sites More sharing options...
