Hello Paul,
Thank you for using the Unitronics Forum.
Unfortunately, at this time, there is no way to make the "length" option variable.
The import function will allow you import a preconfigured mixed data location from a file; for instance, an I/O configuration.  It is usually used when configuring an expansion adapter (EX-RC1) with a UniStream controller.
Hope this helps!
