Malcolm Posted December 23, 2010 Report Share Posted December 23, 2010 Hi guys, Does the Unitronics PLC support to use modbus RTU Slave on one port and modbus RTU master on the other to have two different modbus nets? Regards, Quote Link to comment Share on other sites More sharing options...
Stein Yair Posted December 26, 2010 Report Share Posted December 26, 2010 Hi, Unitronics PLCs allow you to configure each port independently through the ladder, so that one port is master and the other one is slave. Moreover, if you are using a PLC which contains Ethernet, you can configure each of the 4 sockets as either master or slave. Quote Link to comment Share on other sites More sharing options...
Malcolm Posted December 27, 2010 Author Report Share Posted December 27, 2010 Thank you Stein! I have done this before with the Ethernet but will be my first time with the RS 232/485 ports. Quote Link to comment Share on other sites More sharing options...
