wachovius Posted January 6, 2015 Report Share Posted January 6, 2015 Hi, as this is my first post I want to say hello to everybody in this forum. I am facing a problem trying to communicate with a JZ-11 via the serial port. My environment: Linux box (raspberry pi) connected to Jazz via USB program cable (which is working fine as I can communicate with this cable on a Win 7 64 Bit box), serial line parameters are 9600 baud, 8bit, No parity, 1 stop bit. I am sending an ASCII-based string to the Jazz to read the RC-clock value as described in http://www.unitronics.com/docs/technical-library/com.pdf?sfvrsn=0. For communcation I am using a serial class library for Python (pySerial). The string I send is "/00RCF5\r" which correspondes to the "Read RTC" command (page 6 in the Unitronics document). Unfortunately when waiting for a reply from the Jazz I am waiting forever. Does anybody have an idea how I can solve this issue? Thanks in advance, Markus Link to comment Share on other sites More sharing options...
Eyal Koren Posted January 15, 2015 Report Share Posted January 15, 2015 Hi Wachovius, You can try and connect the Raspberry Pi to a PC and use a serial terminal to monitor exactly what signal the PC receives. My assumption regarding this is that the Raspberry Pi is using a TTL serial communication and not RS232 serial communication layer. You can find more about the differences between these two here. Another thing: the standard communication parameters of the Jazz are as follows: Baud rate 9600 Parity: Even Stop Bits 1 Data Bits 7 Link to comment Share on other sites More sharing options...
INALIMCO Posted March 8, 2015 Report Share Posted March 8, 2015 Hi i am new using jazz oplc i am tryng to program a jz10-11-un20 and it is giving me problema with comunication i am using a MJ20-PRG with MJ20-CB200 cable MJ10-22-CS10 and all of these join to mi computer wit a Logitech USB to serial DB9 converter the problen is the software U90 LADER after i configure all the com parameters tels me cant find com port 1 iven if i change the com port in the computer and the software to any other com port i was wanderinf if the Logitech convertion usb to rs232 is not adecuate to do the job Tanks in advance for your help PD sorry about my english i am a spanish speaking people Link to comment Share on other sites More sharing options...
AlexUT Posted March 8, 2015 Report Share Posted March 8, 2015 Hi, I recommend you to use Unitronics approved USB-to-Serial converters. You can find converters by contacting your local distributor in your country. MJ20-PRG is isolated, and require external power, which is obtained from USB-to-Serial converter, DSR for example. Your USB-to-Serial converter will be simplest one, which use only Rx and Tx lines. So it cannot supply power to PRJ adapter. B.R. Link to comment Share on other sites More sharing options...
