Cara Bereck Levy Posted January 26, 2015 Report Share Posted January 26, 2015 This version supports an addition to the award-winning Vision line, the Vision430™, 10 models with a 4.3" graphic touch-screen and onboard I/Os. § V430-J-RH2- 12 digital inputs. 2 may be configured as analog, and 3 as HSC/shaft-encoder inputs- 6 relay outputs § V430-J-R34- 22 digital inputs. 2 may be configured as analog, and 3 as HSC/shaft-encoder inputs- 12 relay outputs § V430-J-TR34- 22 digital inputs. 2 may be configured as analog, and 3 as HSC/shaft-encoder inputs- 8 relay outputs - 4 high-speed npn transistor outputs § V430-J-RH6- 8 digital inputs. 2 may be configured as analog, and 1 as a high-speed input- 4 analog inputs- 6 relay outputs § V430-J-RA22- 12 digital inputs. 2 may be configured as analog, 2 as PT100/TC, and 1 as HSC/shaft-encoder inputs- 2 analog, inputs- 8 relay outputs- 2 analog outputs § V430-J-TRA22- 12 digital inputs. 2 may be configured as analog, 2 as PT100/TC, and 1 as HSC/shaft-encoder inputs- 2 analog inputs- 4 relay outputs- 2 analog outputs- 4 high-speed npn transistor outputs § V430-J-T2- 12 digital inputs. 2 may be configured as analog, and 3 as HSC/shaft-encoder inputs- 12 transistor outputs. 7 may be configured as high-speed outputs § V430-J-T38- 22 digital inputs, 2 may be configured as analog, and 2 as HSC/shaft-encoder inputs- 16 transistor outputs. 7 may be configured as high-speed outputs § V430-J-TA24- 12 digital inputs. 2 may be configured as analog, 2 as PT100/TC, and 1 as HSC/shaft-encoder input- 2 analog outputs- 10 transistor outputs. 5 may be configured as high-speed outputs § V430-J-B1This model does not comprise an I/O configuration Download the version here. Link to comment Share on other sites More sharing options...
