navigatoru Posted February 5, 2015 Report Share Posted February 5, 2015 Hi, There is any option to have a timer showed on the HMI? Basically I need to see for example TD1 (which is 3 minutes) on the HMI decreasing to 0. Cheers, Marius Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted February 5, 2015 Report Share Posted February 5, 2015 Hi Marius, Please see the attached image. There is a Timer/Counter HMI variable that presents timer values. you can present and/or edit both preset and current timer values. Quote Link to comment Share on other sites More sharing options...
navigatoru Posted February 6, 2015 Author Report Share Posted February 6, 2015 Hi Eyal, Thanks for reply. It is working perfectly. Cheers, Marius Quote Link to comment Share on other sites More sharing options...
