darknesspic Posted February 18, 2015 Report Share Posted February 18, 2015 I'm using V120 with scale that the scale send the data at all time and Unitronics will read the data but the PLC can not get the data. Please advise. Init function block:Databit=8,standard=RS232,BaudRate=9600,Parity=None,IgnoreBreak,StopBit=1 Scan function block:no use STX,ETX and anther block same the sample Please guide me.Thanl you Quote Link to comment Share on other sites More sharing options...
AlexUT Posted February 22, 2015 Report Share Posted February 22, 2015 Hi, What is a format of data string from Scale? Is number of transmittet characters fixed or floating? What is a pause between messages? B.R. Quote Link to comment Share on other sites More sharing options...
