pstrickland Posted January 3, 2011 Report Share Posted January 3, 2011 I am using a JZ10-11-UA24 to control a motor with +- 10 vdc. I am inputing an 8 bit unsigned register from a CNC (I0 to I7). With the Linearization Function, I can scale my analog output (-4095 to 4096). My 10 volts does not scale correctly. Any sugestions would be appreciated. Link to comment Share on other sites More sharing options...
Emil Posted January 3, 2011 Report Share Posted January 3, 2011 Can you explain what are the values for linearization and what exactly is the problem? Link to comment Share on other sites More sharing options...
Jas Posted January 3, 2011 Report Share Posted January 3, 2011 Please see the attached commented example program I created. It will take inputs 0-7, convert them to an integer register, and then perform linearization to go from 8-bit to 12-bit (0-10V). Linearization is performed on the HMI variable to display the 12-bit value as a voltage on screen. UA24 Bits to Numeric + Linearization.U90 Link to comment Share on other sites More sharing options...
