ramcikas Posted March 14, 2015 Report Share Posted March 14, 2015 Hi, i'm want to make a project with weekly timer for air exchanger with 4 speed (relay outputs), but have some problems, can anyone add example??? PLC -Samba SM35, Best rgds, Ramunas Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted March 15, 2015 MVP 2021 Report Share Posted March 15, 2015 Create a TD timer for 24 hours that increments an MI. When the MI gets to 7, trigger your event and reset the MI. Alternatively, if your event needs to occur at a specific time of day, do a comparison between the RTC and the time you want. When equal, increment the MI. When the MI equals 7, trigger your event and reset the MI. 1 Quote Link to comment Share on other sites More sharing options...
ramcikas Posted March 29, 2015 Author Report Share Posted March 29, 2015 Hello Flex727, thanks for help, but I'm not very successful, I was confronted with double coil syndrom. can you add prinscreen Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted March 30, 2015 MVP 2021 Report Share Posted March 30, 2015 Use MB0 as a contact for whatever you are needing to do on a weekly basis, but be sure to reset it - or you can change it to a Direct Coil and it will be True for a single PLC cycle. Quote Link to comment Share on other sites More sharing options...
