lluisot Posted April 7, 2015 Report Share Posted April 7, 2015 Hi , i want connect Android scada Unigo with v130 by Modbus TCP . Is possible this ? Best regards from Spain Link to comment Share on other sites More sharing options...
Alexander Posted April 7, 2015 Report Share Posted April 7, 2015 Hello, UniGo is an App created by a third party developer. Though it was designed to work with our products, we do not directly support their applications. I would recommend contacting them for any questions or support. Though other forum members have used it and could better help out. Best of luck! Link to comment Share on other sites More sharing options...
lluisot Posted April 8, 2015 Author Report Share Posted April 8, 2015 Thanks Alexander. My idea is connect scada with Modbus TCP, but i do´nt know if V130 support Modbus TCP in server mode . Do you know this ? Best Regards Lluisot Link to comment Share on other sites More sharing options...
Alexander Posted April 9, 2015 Report Share Posted April 9, 2015 Yes, as long as an Ethernet card has been added to the V130 then the unit supports Modbus IP in both server and client mode. Our Ethernet card can utilize 4 sockets that can be set up independently as any configuration of client and server. This would you to set up all 1 socket as a Modbus IP server, and the rest can be configured for other functions or additional Modbus servers/clients. Link to comment Share on other sites More sharing options...
lluisot Posted April 10, 2015 Author Report Share Posted April 10, 2015 . I will buy a ethernet card for the test. Thanks for all . Link to comment Share on other sites More sharing options...
lluisot Posted April 11, 2015 Author Report Share Posted April 11, 2015 Hy , my idea is connect Scada Android with industrial ehernet Router 3G. V130 is conected to router with a ehernet card . it's possible Modbus TCp also? Link to comment Share on other sites More sharing options...
Alexander Posted April 13, 2015 Report Share Posted April 13, 2015 Yes, Modbus over an Ethernet TCP/IP connection is commonly referred to as Modbus IP. Link to comment Share on other sites More sharing options...
jweav2223 Posted April 17, 2015 Report Share Posted April 17, 2015 Your 3G Router would have to be provisioned with a Publicly Accessible Static IP Address to be able to connect remotely with the Android SCADA App. I use the Unigo for Android as well as an iOS App regularly for remote monitoring of installations. I have used this setup on 2G, 3G and 4G/LTE Networks with success. Link to comment Share on other sites More sharing options...
lluisot Posted April 17, 2015 Author Report Share Posted April 17, 2015 Your 3G Router would have to be provisioned with a Publicly Accessible Static IP Address to be able to connect remotely with the Android SCADA App. I use the Unigo for Android as well as an iOS App regularly for remote monitoring of installations. I have used this setup on 2G, 3G and 4G/LTE Networks with success. Thanks for your asnwer . For a safe connection is necesary a VPN Net ? Best regards Link to comment Share on other sites More sharing options...
jweav2223 Posted April 20, 2015 Report Share Posted April 20, 2015 Not required. More of your own preference I suppose. Link to comment Share on other sites More sharing options...
