Brad Donovan1 Posted May 31, 2015 Report Share Posted May 31, 2015 Hi all, I have an M91 with the text on the screen being upside down. Had one a few years ago with the same problem and though it was an easy fix back then, but can't find anything in the help files. Brad Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted May 31, 2015 Report Share Posted May 31, 2015 Hello, Attached is a program for rotating the display back to normal. Connect the PLC to the PC, choose the com port and the direction and click on flip display. Please let us know if it solved the problem. Filp M91 Display.exe Quote Link to comment Share on other sites More sharing options...
Brad Donovan1 Posted May 31, 2015 Author Report Share Posted May 31, 2015 Thank you for this, but it didn't work. I check comm ports and it is the correct one, 232 port 1. Brad Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted June 1, 2015 Report Share Posted June 1, 2015 Hi Brad, thanks for the update. try to use U90Ladder V6.6.6 from Unitronics website. install the software and download the latest O/S , then download a blank project (HW Configuration only) Go to info-mode and check if the charecters still fliped. if the problem still occure so contact support@unitronics.com for service issue. i hope it helps.. Quote Link to comment Share on other sites More sharing options...
Brad Donovan1 Posted July 13, 2015 Author Report Share Posted July 13, 2015 Hi, I have only just had time to get back to this unit and its problem, followe through with your thoughts and alass, no luck, off to support@unitronics now, thanks. Brad Quote Link to comment Share on other sites More sharing options...
dano3829 Posted December 30, 2019 Report Share Posted December 30, 2019 Hi, This executable worked for me. I don't know how or why the Display got flipped in field. Thanks for putting this online in 2015. ***Part of post, not related to display rotation correction, being deleted*** Quote Link to comment Share on other sites More sharing options...
