kurt Posted August 6, 2010 Report Share Posted August 6, 2010 Hi I am new. I want to send by rs232 a variable to a display. I dont now how to make the settings for protocol Who can help me thanks. Link to comment Share on other sites More sharing options...
Anthony Posted August 6, 2010 Report Share Posted August 6, 2010 Hi Kurt, If you go to help-->Examples and browse to Version 850\Project examples\Communications\FB Protocol you will find an example called V130_Send_number_and_string .vlp You will find a good example of how to send strings out ont he RS-232 port. Link to comment Share on other sites More sharing options...
kpark Posted September 29, 2011 Report Share Posted September 29, 2011 Does this run on a V130-T38? I modified the hardware (to be a T38) to run that example program, and it does not appear to work. I can use the Unitronics programming cable as my comm cable, correct? Link to comment Share on other sites More sharing options...
Ofir Posted October 17, 2011 Report Share Posted October 17, 2011 Hi, First of all FB Protocol is supported by all the Vision series controllers. If you are connecting the PLC to your device then you need to check the pin out (RX, TX and ground signals) and make sure that the cable you are using match the wiring. You can find the PLC pin out in help topic communication --> RS232 Link to comment Share on other sites More sharing options...
