darknesspic Posted July 14, 2015 Report Share Posted July 14, 2015 The V280, I have a numeric value with a hex format but when its display on HMI it will be decimal, how to display this numeric as hex format? Thank you. Link to comment Share on other sites More sharing options...
cantcliff Posted July 14, 2015 Report Share Posted July 14, 2015 I believe you want to use the Num to ASCII function block as it allows you to convert a number to an ASCII string with a select format such as decimal, Hex, binary or float. Look in the main Ladder Programming manual, page 161 (PDF page 170) Link to comment Share on other sites More sharing options...
Walkerok Posted July 16, 2015 Report Share Posted July 16, 2015 When you make a number display/entry box on the screen you can select on the left hand side for the display box to be in Decimal/Hex/ or Binary. It will allow you to have an MI show as a HEX on screen and allow you to enter a value in HEX and save it correctly in the MI as the decimal the internal calculations/pointer need. Good Luck Keith Link to comment Share on other sites More sharing options...
