guilherme_pires Posted August 24, 2015 Report Share Posted August 24, 2015 Hi, I am new to PLC programming, I need to divide a double word (DW) in two ML, because we are programming a remote acess and the program only accept ML not DW. Anyone Know how can i do that? My PLC is V570. Thanks, Guilherme Quote Link to comment Share on other sites More sharing options...
s.pratt Posted August 24, 2015 Report Share Posted August 24, 2015 Hello, A DW and an ML are both 32-bit integers. The only difference is the DW is unsigned, and the ML is signed. Therefore, you can just store the DW straight into an ML, as long as the value in the DW is not too large (i.e. over +2,147,483,648). Quote Link to comment Share on other sites More sharing options...
guilherme_pires Posted August 24, 2015 Author Report Share Posted August 24, 2015 Hello, Thanks for the reply , but if my DW is more than +2,147,483,648 , I can divide it into two MLs ? I am using that in a flow meter in high-speed input , so that the value in the DW is more than +2,147,483,648 . I saw on the high-speed input I can use ML , so I have a doubt whether the value in ML is more than +2,147,483,648 that will rewrite automaticaly or i need to do a reset on the ML? This is my program: Quote Link to comment Share on other sites More sharing options...
s.pratt Posted August 27, 2015 Report Share Posted August 27, 2015 Hello, I am unsure what you mean by "divide it into two MLs". Are you trying to build a larger integer out of two MLs? If so, it is not possible to create integers out of two other integers. The range for a DW is 0 to +4,294,967,295. The range for an ML is -2,147,483,648 to +2,147,483,647. The largest number the controller can handle in an integer is 4,294,967,295. Since you are working with pulses from a HSI, the pulses cannot be negative. So there shouldn't really be a need to use MLs for the HSI. Hope this helps. Quote Link to comment Share on other sites More sharing options...
cantcliff Posted August 28, 2015 Report Share Posted August 28, 2015 Typically if you overflow an integer data type it rolls over to it's maximum negative number and counts from there which can cause some pretty weird issues if you haven't accounted for it. What is the goal of the high speed counter? What happens with the count when you're done with it, or when it reaches a setpoint? Quote Link to comment Share on other sites More sharing options...
