kurtv Posted January 17, 2011 Report Share Posted January 17, 2011 Newbie Hi I use a loadcell io-lc3 but i want work. i want to configuration to 0 and then to 25000 kg. I try i on the same way of the example but i want work I have a silo i a want to see continu the capasity in the tank the max value is 50000kg I do not need tara. Can any one help me how to program it true and to configuration. And in the configuration do i need the block acquire tara like the example? Thanks Regards Quote Link to comment Share on other sites More sharing options...
Stein Yair Posted January 18, 2011 Report Share Posted January 18, 2011 Hi, It's best to work according to the examples in VisiLogic. You can find them in Help > Examples > ... > Project Examples > LoadCell. If you need any further help, post your application and describe the problem in detail. Quote Link to comment Share on other sites More sharing options...
kurtv Posted February 16, 2011 Author Report Share Posted February 16, 2011 Thanks. It is working perfect Regards. Quote Link to comment Share on other sites More sharing options...
