vamalgise Posted November 16, 2015 Report Share Posted November 16, 2015 Hello everybody, I try to use Jazz JZ20-R16 with add-on MJ20-PRG module kit to communicate with PC by an old PSTN voice/fax conexant modem. I dial up from PC-side modem to PLC-side modem. The communication by a phone line does not pass through when i use standart pinout as in the manual.(http://www.unitronics.com/KnowledgeBase/U90Ladder/Communications/Modems/PLC_to_Modem_Connections_and_Pin-outs.htm) I use the same AT initial strings as I use with M90 controller ( with M90 it works), manual says the cable should be different from M90 cable (should be 6 wire). Please help me with pinout for the modem adapter. PS with M90 I used non-standart pinout( instead of connecting 6-7 pin of DB9 adapter for the modem, I connected 4-6 and 7-8). . Link to comment Share on other sites More sharing options...
