Frodeg Posted December 7, 2015 Report Share Posted December 7, 2015 I use Com port 2 to Modbus, Com port 1 i want to use to a modem. But as son as i change Tx/Rx to Modem the Modbus communication at Com 2 stop, when change back to Tx/Rx and repower, Modbus work again. Should this work? Quote Link to comment Share on other sites More sharing options...
Interroga Posted May 7, 2018 Report Share Posted May 7, 2018 Any anwser? I need create app the same way. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted May 7, 2018 MVP 2021 Report Share Posted May 7, 2018 I might be wrong, but I recall a post some time back where the implication was that settings were not separate on the com ports, even though they should be. I don't think an answer ever came back about it, either. Further comments from the Creators in particular, please? cheers, Aus Quote Link to comment Share on other sites More sharing options...
