Data Table Headers
The description is only used with the ladder logic for reference.
The tables themselves can only hold the data type for the column, so it wouldn't be possible to only have a single row of ASCII strings for units. Though one possible solution is to modify the tag names used for each column that contains the engineering unit. For example a tag can be named Pressure (PSIG) or Temperature (F) with the brackets if that will work for your application.
