OK, its me again
with the realization that my system is slower than I wanted, I need to work out how to do a FIFO or shift register.
My plan is to get the read from the scanner and then depending on that set a bit either low for good read or high for bad read.
I would then use a change in status bit to move that bit across in a register somewhere
Im thinking that I will only have about 4 bits of usage prior to reaching my blow off device,
There is a sensor which I would use to decrement the bits down, so if a high bit was at the right place and the right time then the blow off would operate.
Im looking for suggestions on how to do this quickly and easily!
Thanks
