Guest Manganri Posted May 9, 2016 Report Share Posted May 9, 2016 when i set Analog inputs to 0-10v and link to MI register the value is always around 10, i connect 0-10v to GND and +input and change voltage level nothing happens, if i set Analog input to mVolts it changes, same as temperature, but can not get reading on the 0-10v range. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted May 15, 2016 MVP 2021 Report Share Posted May 15, 2016 What value are you seeing in the MI register? Can you post your code? Joe T. Quote Link to comment Share on other sites More sharing options...
