ORSO2001 Posted June 1, 2016 Report Share Posted June 1, 2016 Dears All, I have upgrded two laptop (home and work) with the last version 1_17_58; in the laptop that I use in my home the menu Modbus Advanced is not more present...same thing if I open an existinfg project or if I create a new one; in the laptop that I use at work the menu is present. what I have to do to enable again the menu? I have alredy dowloaded the program and try to install it many times. If can help: home PC has Win10; work PC has WIN7pro thanks Quote Link to comment Share on other sites More sharing options...
Saragani Posted June 2, 2016 Report Share Posted June 2, 2016 What do you mean by Menu? Do you mean the elements in the Ladder toolbox? If so, then you should enable it within the program options: Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted June 2, 2016 Author Report Share Posted June 2, 2016 Dear Saragani, yes I mean the elements in the toolbox and yes it was disabled, now works thanks Quote Link to comment Share on other sites More sharing options...
