amire@amiad.com Posted June 13, 2016 Report Share Posted June 13, 2016 Hi, I'm using V570. I'm, using button positive transition to change HMI display and to set some MB. many times the display change but the MB does nor set. what can be the reason for that? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted June 14, 2016 MVP 2021 Report Share Posted June 14, 2016 Can you post your code? Joe T. Quote Link to comment Share on other sites More sharing options...
