James_NZ Posted February 8, 2011 Report Share Posted February 8, 2011 We are having a few issues D/Ling a piece of our code to the vision 290 PLC's. We have OS5.04(B13) on the PLC which matches the OS5.04 (we not sure of build match though) the code uses. It gets to 91% via Serial or TCP/IP and then looses its connection. We have tried using Visilogic 9.01, Remote access 9.01 and remote access 6.01 with the same results. Its D/Ling a piece of our code using OS4.72(B26) well with no problems. We also have a PLC that won’t respond to the tap trick and stays loading in Boot Strap Mode (I suspect due to the above problem). We can get the info about its OS etc from the PLC but it will not DL or communicate more than that. Does anyone have any ideas – we are getting stuck fast. Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted February 9, 2011 Report Share Posted February 9, 2011 Hi, First, Go to VisiLogic help menu and update the O/S from the web. Then open your application and make sure to use the following communication parameters: Baud rate - 57600 Time out - 6 sec Go to connection menu>communication & o/s > Operating system tab and check for the latest o/s. Download the application again. if you have the same problem, go to Project menu and create a dvi file (for UniDownloader) go to Tools menu>UniDownloader Designer>and import your DVI file to UniDownloader project.vlp only, no o/s needed. Then download the UDC file to the PLC Let us know if it helps! Quote Link to comment Share on other sites More sharing options...
James_NZ Posted February 10, 2011 Author Report Share Posted February 10, 2011 Thanks for the help. I already had the lastest version OS but checked again anyway, I then attempted to download the application using Remote Access with the following communication parameters: Baud rate - 57600 Time out - 6 sec The download failed at 91% as before. It seems as if the controller was resetting itself twice, and I lost communication on the second reset. I created a UniDownloader UDC file with the application only (no o/s). Then downloaded the UDC file to the PLC - it worked. I did this to two controllers with the same results each time. I am happy its working but should it work with remote access? Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted February 13, 2011 Report Share Posted February 13, 2011 Hi, Can you please tell us, did it happens also with blank app? Quote Link to comment Share on other sites More sharing options...
James_NZ Posted April 14, 2011 Author Report Share Posted April 14, 2011 Sorry its taken a while for me to get back. We are using the unidownloader for technicians in the field so we are able to operate ok. The blank .dvi application works no problems with OS5.04B18 & B20. The issue only appears with our application on both OS5.04B18 & B20. The issue does not appear when we make a unidownloader file with the troubled dvi in either OS. Therefore I think the problem may be somewhere in our application, but why do both the unidownloader and visilogic work? I have inherited this code but I am more familiar with it now. Having said that I cannot solve this issue. What are your thoughts about how to go about solving it? It’s not urgent but we'd like to solve it as remoteaccess is our primary tool for technicians. Kind Regards James Quote Link to comment Share on other sites More sharing options...
