Onionprint Posted October 14, 2016 Report Share Posted October 14, 2016 I was reading this document for the USP-104-B10. It says it can hold up to 5 modules. I have never used one of these and would like to know if the CPU consumes some of these slots. I am hoping I can fit a USC-P-B10 and three UID-W1616R onto one USP-104-B10. Other wise I will have to get an extension module and am not sure which one to get at the moment. Thanks Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted October 16, 2016 MVP 2014 Report Share Posted October 16, 2016 Hi, The CPU does not consume one of the IO slots. So you can have a CPU plus 5 IO modules. The capacity of 5 modules are the narrow style. You would like to use the UID-W1616R which is a wide module and they are 1.5x wider than the narrow ones. This is equivalent in width to 4.5 narrow modules, so you are OK, but won't be able to fit any more modules directly on the PLC. Quote Link to comment Share on other sites More sharing options...
