SQL or VISUAL-BASIC programming or either mathematical-'Floor' function on visiologic
Hello,
I have some mathematical functions I find it easy to code on either STL or Visual-Basic subroutine.
Does anyone know is there a way to do this on visiologic (for V230 CPU)?
Alternatively, mathematical-"Floor" function can be almost enough to start with.
Please advise...
Sincerely,
Adin.
The V230 is an older unit with the Standard instruction set.  It's not very powerful when it comes to numbers.
You'll have to upgrade to one of the newer units with the Enhanced instruction set.  If you were to open a new project in Visilogic and select a V570 or bigger you could explore the floating point operations and see if they will fit your needs.
If you're stuck with the V230 then you're kind of out of luck.
