MarkAB Posted November 2, 2016 Report Share Posted November 2, 2016 Need to create remote EtherNet/IP IO either a EtherNet/IP module that will replace the EX-RC1 but allow use of Visilogics Remote IO. Or something along the line of the Turck FEN20-4DIP-4DXP with additional options for IO and analog. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted November 2, 2016 MVP 2021 Report Share Posted November 2, 2016 The Vision series does not support EtherNet/IP. You'll have to upgrade to a UniStream to do this. You can use the Turck unit with the existing system by setting it up as an Modbus IP slave and mapping bits to it in your program. Joe T. Quote Link to comment Share on other sites More sharing options...
