pingwindaboss Posted November 15, 2016 Report Share Posted November 15, 2016 Hi, Just before shutdown of Visilogic (9.8.31) i managed to unpin main top toolbar - one containing Project/Edit/View etc. After relaunching program whole bar is hidden. I'm seeking way to restore it without reinstalling environment... I also noticed that when working on 3 screens quite often combo boxes fails to show up when window is not located on primary display. Quote Link to comment Share on other sites More sharing options...
Cam Posted November 16, 2016 Report Share Posted November 16, 2016 Glad to see I'm not the only one to have done this. The best solution is to uninstall and then reinstall Visilogic, however I did find a work around when I had done this this is not a recommended fix just something I found that works. I run multiple versions of Visilogic on my PC and swap using Version Swapper. In your Unitronics directory under the Main file folder there is a layout folder, inside it is a file User Layout.lyt . I renamed the *.lyt file in the directory and then copied the layout file from one version in which the tool bar was visible to the one in which I had lost it, when I re-opened Visilogic my main tool bar was back. 1 Quote Link to comment Share on other sites More sharing options...
pingwindaboss Posted November 17, 2016 Author Report Share Posted November 17, 2016 Indeed that workaround worked great. You just saved me great deal of IT paperwork Quote Link to comment Share on other sites More sharing options...
