Javier Camusso Posted November 17, 2016 Report Share Posted November 17, 2016 Hi everyone. I tried to use a MODBUS configuration using an indirect declaration of SLAVE ID, but didn't work. (You can see an example in index 2 and 3 of the attached image) If I declare the SLAVE ID in a direct way, all OK. My problem is that I have to read several slaves from the PLC, and is realy hard to do with a fixed Modbus confifuration. I'm using a V130 in version 9.6.0. Thanks in advance. Regards, Javier. Link to comment Share on other sites More sharing options...
DanT Posted November 21, 2016 Report Share Posted November 21, 2016 (edited) Hi; Moderator : withdrawn, Dan Edited November 21, 2016 by DanT Withdrawn, did not address the Indirect issue directly Link to comment Share on other sites More sharing options...
DanT Posted November 23, 2016 Report Share Posted November 23, 2016 Hi; I did a test myself. Have you Set up the TCP Connect properly to look at the MI with the Slave Address? and is there an IP Address entered at the MI ? DanT Link to comment Share on other sites More sharing options...
