Guest OREILLEJ2899 Posted January 23, 2017 Report Share Posted January 23, 2017 Why does the "Store to DTI File" function create multiple files when I set "F" Parameter to #1 (Create CSV file). I expected just a CSV file, but it created a "*.UDTF", "*.CSV", and a "*.CSV.ZIP" on the SD card too? I would prefer the program only to save the DT to "*.CSV file". DTI Infolog Sub.pdf Quote Link to comment Share on other sites More sharing options...
Ofir Posted February 5, 2017 Report Share Posted February 5, 2017 Hi, You are correct. When saving Data table to file and parameter F is selected it will generate 3 files: 1. UDTF - This is data table format of Unitronics. You can use this file later when you wish to load the data back to the PLC. 2. CSV.zip and CSV - At start we had only CSV.zip since we wish to compress the file to save storage but then we got requests to have a CSV not zipped. (some smartphone could not open zip that was sent by mail). Anyway I believe you should not have any issues of space in the SD card. BTW you can use File Operation - Delete file to remove files. Quote Link to comment Share on other sites More sharing options...
