UNICO2 Posted February 1, 2017 Report Share Posted February 1, 2017 Hi - I have an Unistream panel connected to an UAG-XK-125 with 4 relay cards on the rail (UID-0016R's). My question is when I download a new program to the panel are the UID-0016R's identified or written to in any way? My concern is that I am downloading, then disassembling the UID's (disconnecting the wiring connectors)and then shipping them somewhere and then reassembling them again. I won't be there when it is all re-connected. Do the UID's need to be reconnected in the same exact order they were disconnected (RLY0,RLY1,RLY2,RLY3) - will the I/O tags move or anything else be changed? They are all the same type UID-0016R. Or can they use any UID-0016R in any order? Thanks. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted February 2, 2017 MVP 2021 Report Share Posted February 2, 2017 The particular modules are not assigned any kind of ID; they're not smart. As long as the right module type is in the right place in the module string you'll be OK. Joe T. Quote Link to comment Share on other sites More sharing options...
UNICO2 Posted February 2, 2017 Author Report Share Posted February 2, 2017 The older I get, the dumber I like my technology...cause they never seem to be thinking what I'm thinking! Quote Link to comment Share on other sites More sharing options...
