richlinares@gmail.com Posted February 7, 2017 Report Share Posted February 7, 2017 Hello, I wanted to ask if anybody knows how to or has created a "running timer". I have a bit that is going to turn on/off based on a set point. I would like to track how long the bit remains on over a period of a few days. I thought i could use TA timer but it appears that it works only with a loaded preset and counts down from the preset. any suggestions would be very welcomed. thank you RL Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted February 8, 2017 MVP 2021 Report Share Posted February 8, 2017 Use the bit in combination with SB 13 and an Increment block on an ML: I'll leave it as an exercise your you to break the accumulated seconds into hours, minutes, and days. Joe T. 1 Quote Link to comment Share on other sites More sharing options...
richlinares@gmail.com Posted February 8, 2017 Author Report Share Posted February 8, 2017 Thanks for the reply, i appreciate the help. i will definitely work out the rest. RL Quote Link to comment Share on other sites More sharing options...
