Bioprocess Posted February 22, 2011 Report Share Posted February 22, 2011 Dear all, I had problems with a virus in the previous weeks. Now, my computer is clean, but Visilogic doesn´t work. I have installed/uninstalled different versions (from 5.0 to 8.6), according to the recommendations in other topics of this forum, but Visilogic doesn´t start. I always received the same message: Error ‘-2147319779 (8002801d)’ Automation error. I hope you can help me. Thank you in advance. Quote Link to comment Share on other sites More sharing options...
Stein Yair Posted February 23, 2011 Report Share Posted February 23, 2011 Hi, Try the following: Backup your application files. Uninstall VisiLogic. Erase the folder Unitronics VisiLogic_C from C:\Program Files\Unitronics Erase the “Unitronics” folder from- C:\Program Files\Common Files. Install VisiLogic again. Quote Link to comment Share on other sites More sharing options...
Bioprocess Posted February 23, 2011 Author Report Share Posted February 23, 2011 Hi Stein, That's what I did after reading about similar runtime errors in the forum, but it does not work. I'm afraid that a Windows system file (dll or similar) is lost. Do you have any recommendations or should I format my hard disk and re-install Windows XP? Thank you. Quote Link to comment Share on other sites More sharing options...
Stein Yair Posted February 24, 2011 Report Share Posted February 24, 2011 1. Is your Windows 32 or 64bit? 2. Are you using Firefox? if so, try uninstalling it, as VisiLogic collides with FireFox. 3. Install VisiLogic 9.0.1. 4. Launch the Swapper and click on Register. If nothing works, send a screen shot of the error message you receive to support@unitronics.com. Quote Link to comment Share on other sites More sharing options...
