Csoto Posted April 9, 2017 Report Share Posted April 9, 2017 Good day. I´m new at using PLC so i reach to you for some guidance. I have a PLC v570 and i need to register a table when the bobine is turned on or off, in other words, registering 0/1 (or off/on). I´ve registered other information in the table before without any trouble but with the bobine´s registry i found myself a little lost. I'd really appreciate your help. Greetings. Quote Link to comment Share on other sites More sharing options...
Ofir Posted April 9, 2017 Report Share Posted April 9, 2017 Hi, If you wish to log to a data table a value of 0 or 1 you can define the specific column to Boolean and store a value of MB. If you are still facing issues with logging values to the data table , attach the application and explain where is the logic that stores the data to the table. Quote Link to comment Share on other sites More sharing options...
