Fluidpowerman Posted May 1, 2017 Report Share Posted May 1, 2017 Working on a project where I need to email a zipped CSV file created from Data Sampling. I can structure and send emails with no problem. I can see the CSV file via file browser, but having difficulty sending the attachment. My goal would be to allow the operator to choose from a list of csv files that updates as the files are generated from Data Sampler tests. I have tried to link a tag where you configure the email so you can type in the file name on a key pad text box. the keypad entry does not have some of the characters needed to match the file name (ie. -_ etc.). Has anyone sent CSV email attachments and could point me in the right direction? Thank you for your input Quote Link to comment Share on other sites More sharing options...
Ofir Posted January 23, 2018 Report Share Posted January 23, 2018 Hello, As you can see below the characters do exist in the keyboard - in order to get the underscore _ you can press on Shift. BTW please note that in the struct of the data sampling you can change the file name in "File Name" tag. Quote Link to comment Share on other sites More sharing options...
Torfinn9990 Posted January 31, 2018 Report Share Posted January 31, 2018 solved Quote Link to comment Share on other sites More sharing options...
