Keypad, Buttons, and Numeric Variables
 I need to be able to open the Keypad with a Button ( not touching the Numeric Variable) and store the keypad value in an MI where I can use it later in the program.
I need this because , depending on a switch setting, I need a Numeric Variable to:
                  If Switch  = "0" (System Automatic Mode )  then show value from an Analog Input.
                   If Switch  = "1" (System Manual Mode)  show the MI storing the keypad entered value.
I can do the switching, I just need to know how to open the Keypad with a button.
Thanks -
I don't believe you can open the keypad without referencing a numeric variable because the input from the keypad must have a place to go. However, you can accomplish what you wish easily enough. Just copy the analog value into the numeric variable when switch = 0 and disable it. When the switch = 1, then re-enable the variable to allow keypad input.
