Rjustino Posted July 9, 2017 Report Share Posted July 9, 2017 Bom dia, preciso urgentemente de apoio; não consigo , não sei como chamar uma saída num bloco canopen - (XN-GWBR-EATON), (XNE-16DO-24VDC-0.5A-P) , interligado com Vision V1040. Qual comando que uso? Como faço uso das entradas e saídas? -/-*/-*/-*/-/-/-*/-*/-*/*-/-*/-*/-*/-/-/-*/-* Good morning, I urgently need support; I can not, I do not know how to call an output in a canopen block - (XN-GWBR-EATON), (XNE-16DO-24VDC-0.5A-P), interconnected with Vision V1040.Which command do I use? How do I use the inputs and outputs? Link to comment Share on other sites More sharing options...
Guy Sela Posted July 9, 2017 Report Share Posted July 9, 2017 Hi Rjustino To get you up to speed, please refer to Unitronics CANopen video webinar. You can find many example project within VisiLogic itself including CANopen: C:\Program Files (x86)\Unitronics\Unitronics VisiLogic_C\Examples\Version 900\Project examples\Communications\CANopen. More information can be found in VisiLogic Help (F1) under CANopen. Link to comment Share on other sites More sharing options...
Rjustino Posted July 9, 2017 Author Report Share Posted July 9, 2017 Então, já fui lá, mas não consigo entender. Montei um projeto,funcionou, comunicou com o bloco canopen, mas, não sei executar a saída dele. Como o V1040 não tem portas de entrada e saída, preciso saber como. /-*-*/-*/-/-/-/-*/-*/-/-/-/-/- So I went there, but I can not understand. I mounted a project, it worked, communicated with the canopen block, but, I do not know how to run out of it.Since the V1040 does not have input and output ports, I need to know how. Link to comment Share on other sites More sharing options...
Guy Sela Posted July 10, 2017 Report Share Posted July 10, 2017 I commander you to get in touch with our local distributor in Brazil, they are very professional and have a grate support (in Portugais). DAKOL Instrumentos e Sistemas Ltda. Phone:11 3855 0060 Fax:11 3855 0060 Email:vendas@dakol.com.br Website: http://www.dakol.com.br Link to comment Share on other sites More sharing options...
Rjustino Posted July 10, 2017 Author Report Share Posted July 10, 2017 Ok, meu amigo, vou tentar contato com a Dakol de novo. Obrigado. Link to comment Share on other sites More sharing options...
