georgelaser Posted July 15, 2017 Report Share Posted July 15, 2017 Hi, I was wondering how i can program an analog input so i can set a limit through the numpad of the Jazz JZ-10-R16 and when the input exceeds the limit then i can stop an on-going process. Thanks in advance, George Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted July 16, 2017 MVP 2021 Report Share Posted July 16, 2017 I've attached a program showing how to do what you want. I always use two displays for user changeable variable - one to view and one to edit. Press the right arrow on the Jazz to get to the edit screen. You'll see that SB 30 (entry complete) will take you back. The logic is very simple. If you haven't looked yet, there are tons of examples under the Help menu item - see Sample U90 projects. Joe T. Jazz upper limit.U90 Quote Link to comment Share on other sites More sharing options...
