pizelle Posted August 15, 2017 Report Share Posted August 15, 2017 bonjour a touts j'ai acheté une station de traitement de l'eau avec un automate unitronics et le programme de formation. La societe a fermer. J'ai la notice avec les branchement ps (bornier de la station. Sur cette station il ya pompe1, pompe 2, un néon uv .un pressostat de colmatage, un pretossotat de ballon vessie, un compteur eau, un bac disconnecteur avec sonde haut , Moyen, bas, je peux vous envoyez le schéma cordialement jerome Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted August 22, 2017 MVP 2021 Report Share Posted August 22, 2017 Translated: Hello has everything I bought a water treatment station with a unitronics automaton and training program. The company has to close. I have the instructions with the ps connection (terminal block of the station.) On this station there is pump1, pump 2, a neon uv. A clogging pressure switch, a bladder balloon pretossotat, a water meter, a disconnector tank with high probe , Medium, low, I can send you cordially schematic jerome So what is it we can do for you? Joe T. Quote Link to comment Share on other sites More sharing options...
